Originally Posted by fp1529
Thanks I checked the washer fluid and PCV valve they are okay. I do not have a gasket between the cap and where it seats, is there supposed to be one? Can I use a liquid gasket if dealer does not have one? Last question why would the truck miss in the morning but not in the afternoon? Can the humidity cause the distributor miss?
the moisture problem inside the cap is saying the cap must not be installed correctly or water is being directed into the distributor area....
did you use dielectric silicone grease on the plug wires boots ?
also use this grease on the base of the cap....
this is begining to point to bad plug wires/improperly routed wires....this is common as when the plug wires are replaced they are not put back where they belong,,,if necessary use new loom/tyraps to keep wires at the proper position...
excessive plug wire resistance is also a cause of arcing ...this resistance slowly overtime may be 3x the OEM spec..then the voltage starts jumping at any ground point instead of the plug tip.
