Re: Profesional opinion needed pleaase!!
Is this without it connected to the cable?
as your cable may be internally corroded, causing it to seize up.
Other than that I would say drop out the transmission, and check the clutch parts, make sure they are in good condition, and move freely. If they dont then pull the pieces apart, clean them, replace them as necessary.
The fact that you transmission does go into gear is a good sign. I guessing some corrosion has built up in the clutch moving parts causing resistance.
The fact that you can move it by hand is also promising as well.
If the cable is disconnected, check it for free movement.
Remember, dont lubricate the clutch plate, or other internal parts!!!!
Let me know, Ill be checking back on this topic.
