Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-14-2009, 02:40 AM   #1
bthepenny
bthepenny Normal reputation
1993 s-10 blazer 4.3 cpi...another one with fuel problems?
I bought the truck the other day for cheap. the guy said it aint ran in over a year. first thing i did was check to see if i got spark and fuel pressure (just pokin valve not with a guage). both where good. I poured gas down intake and it ran for a second or 2. pulled top of intake and checked the spider out. seems the solenoid wasnt getting a ground so i made one and it sprayed out all the injectors like a champ. put it all back together. and nothing. tried to pour more gas and would not even sputter. check spark again and was still good. any ideas that would help?
thx
bthepenny is offline   Reply With Quote
Old 06-17-2009, 07:41 PM   #2
metallica21156
metallica21156's Avatar
metallica21156 Normal reputation
Re: 1993 s-10 blazer 4.3 cpi...another one with fuel problems?
you may have flooded it pouring gas in it. were the plugs wet?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series split rear, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers. Mag 500's with black center caps, C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
metallica21156 is offline   Reply With Quote
Old 06-18-2009, 01:58 AM   #3
bthepenny
i pulled all plugs after not messing with it for a day or two and they were dry and still wouldnt do anything but im just saying screw it and put a carb on it and call it a day. the only purpose i got the thing was a offroad toy so fuel milage and all that stuff dont matter and where im at its just mud not anything steep so i dont worry about the carb on a hill cutting out
Old 06-18-2009, 07:21 AM   #4
b1lk1
b1lk1 Normal reputation
A helluva alot easier and probably cheaper to fix the current problem. Get someone with a proper OBD II scanner to look at it and if it has 60PSI+ of fuel pressure then the pump is probably good. DO a proper fuel pressure test as well. You will be doing a ton of work swapping it over to a carb and I doubt it will ever run right if at all.
1999 GMC Jimmy SLS (these trucks sure suck the life out of your wallet, LOL!)
Cold Air intake (eBay special with homemade heat sheild)/Throttle plate modded
2" Suspension lift (rear springs/front torsion crank)/1 1/4" read wheel spacers
b1lk1 is offline   Reply With Quote
Bookmarks
Google
Web AF
