Rasing from the depth and old geo
My daughters fiance, has brought me a 1994 4 dr geo metro with a 3 cylinder motor and 5 spd tranny.
I was sitting in a field, and had no water pump in it. the timing cover and several other items are missing.
I have a complete 1993 3 cylinder, and a spare 95 motor in my shop to use for parts.
We have replaced the water pump, and have now moved on to installing the timing belt, only to find none of the belts will fit. the 95 is wider, and the 93 is narrow. Are they all the same length, just different widths? I cant get the darn belt on, no matter what I try.
Also, attempting to remove the bolt off of the crack timing gear (pulley already gone) is next to impossible, the motor turns even with the car in gear, it simply moves the car, and the brakes arent any help as they need to be freed up.
My idea is to raise up the car, and partially drop the motor to get access to the pulley bolt, and try an impact on it.
Any ideas to help speed this up a bit?
