Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 06-12-2009, 09:33 PM   #1
mrsbb
mrsbb Normal reputation
98 Tahoe rear seal leaking
any one know of a web site that shows how to change the rear seal on 98 tahoe. or can someone tell me how? It just started leaking and someone said they were easy to replace without taking it to the garage.
mrsbb is offline   Reply With Quote
Old 06-12-2009, 09:46 PM   #2
toddman67
toddman67 Normal reputation
Re: 98 Tahoe rear seal leaking
Axle seal? pinion seal? what are we talking about here?
toddman67 is offline   Reply With Quote
Old 06-12-2009, 09:58 PM   #3
mrsbb
pinion seal
Old 06-12-2009, 10:16 PM   #4
toddman67
Remove the U-joint straps from thre pinion yoke. put a dimple on the yoke, the pinion shaft and nut or a suitable reference mark for the proper torque of the nut during re-assembly. Remove the pinion nut preferably with an impact gun. Note the posistion of the yoke for re-assembly. Tap the yoke loose from the pinion shaft. Remove the seal.
Install the new seal. Install the yoke in the original posistion. Install the nut and tighten down until the dimples or reference marks line up.
Do not over tighten the pinoin nut! There is a crush spacer that was installed during the original set up for the proper preload and pinion to ring gear set up. This is the reason for the reference marks and yoke posistion.
Old 06-13-2009, 06:59 PM   #5
777stickman
777stickman's Avatar
777stickman Normal reputation
To add to toddman67's excellent advice. Make sure you count the exposed threads before removing the pinion nut. Also clean the nut and pinion threads and apply a small amount of lock-tight to the threads prior to nut installation. You can remove the nut with an impact but install it slowly by hand or ratchet until you reach the number of exposed threads and scribe marks.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 06-14-2009, 06:53 AM   #6
GMMerlin
I know stuff
GMMerlin's Avatar
GMMerlin Normal reputation
To prevent over or under torqueing the pinion nut, prior to disassembly use an beam style inch/pound torque wrench to measure the rotating torque of the pinion...when reinstalling the nut, tighten the nut untill you add 3-5 in/lbs more rotating torque
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Bookmarks
Google
Web AF
