The Horn is Stuck On
Wow, yet another problem with my 85 !!!
At first the horn was dead. No beep. When this happened before I would fix it by removing and reisnserting the horn relay, down by the fuse box. This time the horn started blasting when I started to pull on the horn relay. Pushed it back in and horn got quiet again.
Later, went out and took horn relay all the way out, renisnerted it, and the thing started blasting away full volume again, stuck on.
Currently have the relay out so I can drive in quiet.
Any chance the horn relay is bad this time? The only other thing I can think of is the wiring / connectors on the receptacle the relay plugs into.
