the second is the fact that smoke is pouring out of the back end of the motor
A few questions; is the smoke coming out (off) of the engine, or exhaust pipe? If you had "water all over the engine bay" this could be steam from the water vaporizing when the engine gets warm. If you know the water pump is leaking, replace it and do a pressure test on the cooling system and a compression test on the engine.
