Re: PCV valve on 1995 ford contour
My research shows that the PCV valve is located under the exhaust manifold behind the heat guard on the drivers side of the front of the vehicle. Remove the 4 bolts holding the heat shield on and with a long screwdriver in between the exhaust manifold pry the PCV valve away. The metal tube will bend away and you can assist this bending as you are prying it out, then bend it back in as you put it back in. It's about a 30 minute job and a $5 part that the shop wants $200 to replace.
