Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 06-09-2009, 12:57 PM   #1
redbird7
redbird7 Normal reputation
97 Astro Stiff Brakes
My 97 Astro (~110K miles) developed a leak in the brakes lines running to the rear of the van. I had these line replaced, and ever since the brake has been stiff - a lot of effort is required to slow or stop the van. I took it back to the mechanic, who determined that there was no air in the line. We discussed the "check valve" - not his words, but mine, that prevent complete loss of fluid in the event of a leak, and he indicated that this must be working properly because the Brake light would otherwise be on.
Ideas?
redbird7 is offline   Reply With Quote
Old 06-22-2009, 11:04 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 97 Astro Stiff Brakes
Is the power steering working?
old_master is offline   Reply With Quote
Old 06-23-2009, 09:24 AM   #3
redbird7
Yes, the power steering works fine.
Old 06-23-2009, 08:30 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
Your vehicle has a system called "Hydraboost". It uses hydraulic fluid pressure provided by the power steering pump for both steering and brake assist. That's why I asked about the power steering.
The "check valve" is actually a proportioning valve. It is designed to shut off the flow of hydraulic fluid in the event of a pressure differential in the two circuits, (front & rear brakes). The valve has a switch that turns on the BRAKE light on the dash telling the driver there's a problem, (no kidding!).
A hard pedal with excessive effort to stop the vehicle, is an indication that only one hydraulic circuit is working. It's possible that the electrical circuit is not turning on the light and you are in fact using just the front, or just the rear brakes. To check the switch, ground the wire at the proportioning valve, the BRAKE light on the dash should turn on.
Bookmarks
Google
Web AF
