Re: 98 Stratus Grinding Noise
In my experience the front driver's side bearing goes out first. Usually you can tell which front bearing is the problem by going around a gradual curve in either direction. If the noise gets louder as you're curving to the right, it's the driver's side, if it's louder as you're curving to the left, the passenger. Changing out the bearing is pretty straight forward, remove the wheel, brake caliper and pads, brake rotor and then there are (or at least in my '98) there were 3 bolts with reverse torx heads (E12 I think) coming from the inside of the spindle assembly, remove them, then remove the big nut on the end of the axle (I think around 32mm or so). Using a slide hammer it's usually not too tough to jerk the bearing assembly out of the spindle and off of the cv axle. Installation is the reverse. Just make sure to torque the axle nut to the correct spec, as not doing so seriously increases the chance of decreased bearing life.
