idlekvn4 06-08-2009, 02:34 PM 95 jimmy 4.3 215000mi my idle surges up and down my idle is at 750rpms but will surge ti1200rpms just changed plugs and gas filter. no gas smell ,if i clean the egr valve would it help some or should i be looking for something else.code reader wont reade codes so im repairing blind any help would be appriciated k MT-2500 06-09-2009, 09:35 AM 95 has several diffent VCM/PCM setups. Is it OBD11 or OBD1? Got any check engine lights on? If so you need to get a engine capable scanner on it and read codes. Post back codes. kvn4 06-09-2009, 10:41 AM its obd11. warrentied tps and seems to have done the trick thank you for replying k MT-2500 06-09-2009, 01:01 PM Glad you got it fixed. Thanks for posting back the fix. Did you ever get a code from it? kvn4 06-10-2009, 09:55 AM didnt bother its been working fine ,i ereasd code, my scanner only ereases them early obd11 Automotive Network, Inc., Copyright ©2012
