2002 Alero not cranking overcondor244 06-08-2009, 10:24 AM Ok, back again:loser: So i have a 2002 Alero that i had running for the last almost 2 months or so after having removed the passlock from the vehicle. Now the car won't crank over at all, the injectors and pump both make buzzing noisewhen turning the key on. The starter is good, tested it and all is good. I am going to use a volt meter and check and see if i get power at the starter when turning the key. So i am thinking that it could be the ignition switch and not the cylinder itself seeing as the key seems to operate properly (just a guess). If anyone could chime in and lend a hand, feel free, would love some feedback, Thanks. undersc0re 06-08-2009, 08:29 PM Buzzing could be caused by low juice from the battery or its connections or relays not operating correctly, as well as failing fuel pump. condor244 06-08-2009, 11:59 PM Well i guess it was the security light that was causing the problem......left key turned over to ON for 10 mins till light stopped blinking and turned off, then turned key to OFF, then started right up. Thanks. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
