Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 06-07-2009, 05:28 PM   #1
chd1287
chd1287 Normal reputation
How much ATF?
I pulled my tranny this weekend and am having someone rebuild it. How much tranny fluid will I need when I refill it? Also, how should I flush out the tranny cooler? I'm not too worried about stuff in the lines, the fluid from the pan was clean and had no debris or particles in it. I'd still prefer to make sure though.
chd1287 is offline   Reply With Quote
Old 06-07-2009, 05:54 PM   #2
patbeechermail
patbeechermail's Avatar
patbeechermail Normal reputation
Re: How much ATF?
what is yr make model of your vehicle. and what is tranny model. if you have an air compressor blow air through cooler to clean out.
patbeechermail is offline   Reply With Quote
Old 06-07-2009, 07:33 PM   #3
chd1287
Re: How much ATF?
Oh, sorry. Its a 99 OBS Tahoe with a 4l60e.
Old 06-07-2009, 09:03 PM   #4
j cAT
j cAT Normal reputation
Re: How much ATF?
soap/water flush....then blow air thru it.....best to blow nitrogen gas thru it.....
on a rebuild its about 11qts.....the pan if its the deep pan,will take 5qts....with just the pan/filter maintenance..
make sure the tranny has the correct filter....some filters are not oem design these should not be used....I got the correct deep pan filter at NAPA,,,the filter has the same plastic stamping on it..this sucks the fluid 1 inch off the pan bottom,,,not at the pan bottom where the goop is..
j cAT is offline   Reply With Quote
Old 06-07-2009, 09:10 PM   #5
chd1287
Re: How much ATF?
thanks for the help
Bookmarks
Google
Web AF
