Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Dakota
Old 06-06-2009, 03:46 PM   #1
Doug77
Doug77 Normal reputation
2003 Dakota P0456 code
2003 Quad Cab Dakota 4.7 L
P0456 Evap emissions control leak detected.
Any suggestions? Truck has been idling rough at times when I stop at a stop sign and wants to stall. Once I run it for awhile it goes away. Sometimes.
Doug77 is offline   Reply With Quote
Old 06-06-2009, 11:33 PM   #2
Scotty89
Scotty89 Normal reputation
Re: 2003 Dakota P0456 code
Well the EVAP code can be set from many different things. From leaving the truck running wile filling the gas tank or topping off the tank after the pump clicks. I've had customers that has done both of those. Or it could even be a bad gasket on the fuel cap. There could be a crack in one of the EVAP hoses too. Everytime i've had an EVAP code i've never had the complaint of the vehicle running rough along with it. The easiest way to find an EVAP leak is to smoke the system if you have access to a Emissions smoke machine. If not i would just inspect the hoses and components for cracks or breakage.
Scotty89 is offline   Reply With Quote
Old 06-08-2009, 11:41 PM   #3
hundahunta
hundahunta Normal reputation
inspect the hoses inside of the engine comparment near the booster, also inspect the hoses near the canister espically the 90deg elbow
hundahunta is offline   Reply With Quote
Old 06-19-2009, 08:39 AM   #4
t_arnold
t_arnold's Avatar
t_arnold Normal reputation
Send a message via AIM to t_arnold Send a message via MSN to t_arnold Send a message via Yahoo to t_arnold
I had the same problem with my 2003 Dakota. It was 2 cracked hoses near the Pump, and both hoses were cracked under the truck, near the canister. especially the 90 degree elbow. they were cracked right were they went in to the canister. I was able to trim the ends of those back past the cracks and reinstall them.
Timothy F Arnold
t_arnold is offline   Reply With Quote
Bookmarks
Google
Web AF
