Originally Posted by chuck's
My Suburban has a noticable pulsation in the rear brakes when the pedal is depressed hard.You can feel it even with a normal application but not as noticable.I have eliminated the fronts because when I use the parking brake pedal and apply the rear brakes, the pulsation appears.When it first showed up I took the drums in to get machined.The drums were worn beyond their limit so I bought new ones from Napa.I thought it fixed the problem,but it came right back.I got another set of drums from Napa,changed the shoes,ensured the adjusters worked and tried again.Same pulsation.I would like to eliminate this problem.I would appreciate any assistance in solving this problem.Thanks in advance.
chuck's
If you are 100% sure the pulsation is coming from the back, then what is happening is you have some excessive drum runout.
Typical causes are:
1. improperly adjusted rear shoes...there should be about .020 to .030 clearance between the drum and the shoe..if the shoe is contacting the drum while driving, the drum will heat up
2. heavy application of the parking brake especially when the drums are hot..in most situations, the parking brake does not need to be used..off the top of my head I can only think of 3 times I have applied the parking brake on my Sub.
Check the hardware, if it is sticking the shoes may not release properly.
