No Brakes!!!!
Sanchi
04-01-2003, 12:30 AM
:eek: :eek: ack.. okay guys my brakes are dead!!!! i think my rotors are fwked too. I think this is a good chance to up grade my brakes!!! WHOO HOOO!!!:D :D okay what should i up grade too. Im thinking about getting some 300zx slotted rotors, anyone know if my stock clipers will still work or do i have to change the entire thing!!! or should i just get some slottes rotors that are the same size as the stocks and directly bolt on?!!?!?
For example like these on Ebay.
Cross Drilled & Slotted Rotors (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2408688440&category=33564)
http://ebay3.ipixmedia.com/abc/M28/_EBAY_f0d86439d7bc84ead0fbbec490aeb02b/i-1.JPG
Thankx guys i need brakes!!!!!:bloated: :bloated:
Sanchi
04-01-2003, 01:10 AM
Fliquer did you buy rotors from iROTORS some1 with the same handle left a /msg there with a complant on eBAY. Something about them being too big so you had to grind them down to fit the clipers!?!?!
Fliquer
04-01-2003, 02:36 AM
lol damn you must have been observant to notice that. wow
Yea that was me. Turns out the front rotors they sent me were too large in diameter for stock calipers, and I had to have the calipers sand ground a couple millimeters to fit them. I wouldve contacted them about a refund or a replacement, but I needed my car to have working brakes the next day. iRotors responded saying they wouldve tried to work something out with me, and I semi-believe them.
Looking back, I think it probably would have been a better idea to either get some stock replacement rotors or spend a little more for brembos. Normal rotors have more surface area and provide better stopping power. The drilled ones are pretty much for looks, and I dont think they're worth the extra $ (I paid about $200 incl shipping for the set when I couldve gotten stock ones for less than $100).
Sanchi
04-01-2003, 03:09 PM
kewl ya i was reading the complants and you had one of the 6 complants on his thing heheh. ohh hey so your saying the drilled ones are usless?!?!?! i found some brembos that only have the drilled no slottes?!?! any ideal if thats any good because u said drilled is only for looks?!!?!?
stanner
04-01-2003, 05:13 PM
if you want to upgrade to the 300zx rotors it is much easier if you just upgrade your calipers, and brake cables as well. I could be wrong on this but I think that upgrade only works for the front and not the rear. Unless you are in dire need of the extra stopping power I would just go with stock replacements. I wish you the best of luck in this project.
TatII
04-01-2003, 05:44 PM
300zx brakes calipers bolts right one to the hub. all you gotta do is take out the lugs and replace them longer 300zx ones.
Sanchi
04-01-2003, 08:01 PM
:) :) okay ive decided to just go with some rotors that fit directly with out any moding. I wanted to do the 300zx swap but thats gona take too much time and money, besides i dont realy need all that stoping power. Anyone know what kinda of rotors i should get, back to my question about the slotted and drilled thing. i found some Brembo just drilled, like $180 or something but Fliquer said that Drilled is just for looks?!?!?! im lost now :help: !!!
Fliquer
04-01-2003, 09:50 PM
Yea go for the drilled brembos. Slots might make noise when they scrape against the pads.
Unless you go track racing on a regular basis, holes and slots arent going to do you any good. If you really want better stopping power then you'll need bigger rotors and better calipers.
Sanchi
04-01-2003, 11:40 PM
ALL right!!! im gona go order them tonight i hope there is a chance i can get them by the end of the week!!!! ohh i do hope so!!!
Thankx ALOT Fliquer!! :jump:
:D :D :sun: :flash:
Fliquer
04-02-2003, 01:02 AM
Just make sure its not some deadbeat trying to sell knock off brembos. Good luck with your bidding
Sanchi
04-04-2003, 07:00 AM
Hey Fliquer some guys at Zilvia.net said that iROTOR's get their rotors from Brembo. And that iROTOR's drilles it for us. so if thats the case im getting the same one's you got too bro!!!
