91 jimmys not running right
hello all. i have a 4.3 s15 jimmy. for about the past 4 or 5 months i have had an on going problem with my car randomly bogging down and just running rough. here is a list of all of the things that i have replaced. plugs, wires, cap and rotor, ignition coil, egr, removed cat, map sens, checked vacum lines, and i have recently had a new fuel pump sending unit and fuel filter put in. it no longer runs rough and i have all of the power that i used to have when i first bought it years ago but i still have the problem of it suddenly just lossing power untill i hit the gas and it is fine again. i currently dont have a full exaust from when i cut the cat off thinking that it might be plugged up so i put together a home made exaust with jb weld which of course didnt hold, do you think that this could be causing the problem? any respones would be greatly appreciated!
