Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo/Passport
Old 06-03-2009, 02:10 PM   #1
AWILLIAMS64
AWILLIAMS64 Normal reputation
new engine codes for me
my 01 passport has been acting up lately. flashing cel when accelerating, and now it is on solid. I have the folloing codes po300, po401 and po404. I did the plugs about 40000 ago and did the intake gasket and egr cleaning last summer. here are the symptoms. when starting after it sits for a more than 4-5 hours,,,,starts, dies sometimes, idles really rough. After that it runs fine. when turning it off sometimes, the throttle revs and lowers on its own. up to about 2700 rps then down repeatedly. It runs fine in between those times. Is it time for new plugs again already and an egr clean again?
2001 passport 4wd lx
single din pioneer in dash cd player
single din pioneer in dash 7" monitor
15 years in the car audio industry and i still have stock speakers???
AWILLIAMS64 is offline   Reply With Quote
Old 06-03-2009, 03:11 PM   #2
Cat Fuzz
Cat Fuzz Normal reputation
Re: new engine codes for me
I'm thinking leaky intake manifold gaskets.
The flashing CEL means there is a catalyst damaging misfire. It flashes to communicate a sense of urgency. It's important that you don't drive it like that.
99 Rodeo LS V-6, 4wd, 31x10.5x15 not lifted, Aisin manual hubs.
Cat Fuzz is offline   Reply With Quote
Old 06-03-2009, 07:03 PM   #3
amigo-2k
Isuzu Guy
amigo-2k Normal reputation
2x for leaking intake manifold gasket. see the faq link below for details.
amigo-2k is offline   Reply With Quote
Old 06-04-2009, 02:55 AM   #4
AWILLIAMS64
i sprayed some starting fluid around the intake while it was running and it didnt change the way it ran, also i can not hear any vacuum at this point. I have been driving it for some time, unfortunately i dont have a choice, it seems to run fine while driving. Now the cel is just on solid. I will check the img again this weekend. i hope it is not that again, just did it last summer, i think...or maybe the summer before.
Old 06-04-2009, 10:50 PM   #5
FL 3.2L
FL 3.2L Normal reputation
Do you remember what kind of plugs you put in?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 193K
'96 Jetta 236K
'97 TJ 153K
'03 E46 96K
FL 3.2L is offline   Reply With Quote
Old 06-05-2009, 02:11 AM   #6
AWILLIAMS64
i put in the denso's. i will do the egr clean this coming week to see if that helps.
Old 06-13-2009, 12:59 PM   #7
Steamfitter
Steamfitter Normal reputation
Yeah diagnostics can be so tough with these,my shop manual uses a tech2 scanner for all flow charts.I did not have $3000.00 to get one and then the program card.
I have had those codes in 'o1 3.2L Rodeo sport,I had changed the o2 sensors,nothing then cat converters.I think you may be in that area but it was a while ago.
Intake Man gasket I did twice 129,000 miles on it now,the bakelite spacer cracks and is tough to spot,the starting fluid was a good idea imho,I really wish there was another method to chase problems w/out the tech 2.
I am in a mess with codesP1515,P1125and P1295 along with reduced power lt and it looks like I am alone,here.
I will post my solution when it happpens,sooner the better.
Good luck SF
Fuel pressure regulator will give some crazy codes as well,test the fuel rail pressure.When it went bad it drove the pcm crazy!
Steamfitter is offline   Reply With Quote
Bookmarks
Google
Web AF
