Re: Starter??
If your Rodeo happens to be 2wd, it's fairly easy. If it's 4wd it's a little more involved. You either have to take the motor mounts loose and lift the engine a bit or remove the exhaust 'Y' pipe to get the starter out.
The problem you are having is a very common one with Denso starters. The solenoid contacts wear out unevenly and one is thinner than the other. This is the reason for the intermittent failure. You can buy a solenoid repair kit for less than $20 at Schucks but you still have to go through removing and re-installing the starter.
99 Rodeo LS V-6, 4wd, 31x10.5x15 not lifted, Aisin manual hubs.
