Problem with '99 Regal GS 3.8 (Supercharged)
Google
Web AF
Mr. Marty
06-03-2009, 12:57 PM
As I was driving 60mph down the freeway, my car stalled. I pulled over and tried to restart it. It started but would not idle. I towed it home and changed the fuel pump, fuel pressure regulator and MAS. Problem still exists........It will start but will not idle. I'm out of options. Please help.
GTP Dad
06-03-2009, 07:54 PM
Welcome to AF!!
Did the security light come on? This sounds like it could be a bad crank position sensor that caused the car not to run. Check to see if you have good spark. If not the ignition module or the CPS may be at issue but the CPS is a good bet. The ignition module is easier to change but it can be expensive so check the local wrecking yard for a used one.
Google
Web AF
