Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 06-03-2009, 01:19 AM   #1
Torqued
Torqued Normal reputation
Headliner question
OK, I'm a complete idiot when it comes to interior work. What is the best (means quickest, cheapest, and easiest) way to reattach a headliner that is starting to droop down? This is my commuter car, now, I'm not trying to sell it as a classic.
Torqued is offline   Reply With Quote
Old 06-03-2009, 06:28 AM   #2
Woodie83
Woodie83's Avatar
Woodie83 Normal reputation
Re: Headliner question
Quickest, easiest, and cheapest rarely works in this case. The only way to truly fix it is to remove the board completely, clean all the rotten foam off of it, then glue it back together using headliner glue.
Woodie
98 Metro and 06 Aerio SX
Woodie83 is offline   Reply With Quote
Old 06-03-2009, 11:05 AM   #3
1gasenvy1
1gasenvy1 Normal reputation
Remove all the plastic supports, visors and handles from the interior. Open the back hatch if it's a HB. Stick a broom handle all the way to the front windshield. Be carefull not to "scar" the roofline with the end of the broom stick while pulling down gently (I did this on my first repair). You don't want to bend the cheesey cardboard form. It should release from the metal roof without any problem.
After removal, pull the thin layer of cloth from the headliner. At this time your are ready to re-apply a new cover to the cardboard form. Hancock Fabric, has headliner material. You should be able to get this type at other fabric stores as well, it's a common problem. Apply the spray adhesive designed for this type of material which they should have as well, to both the fabric and cheesey cardboard form. Make sure you have about 2 inches of fabric beyond the edge of the cardboard and fold it over so you have a nice soft edge all around. With you hand press the fabric into the shape of the headliner and your done. Wait 24 hour before you re-install. Use some paneling adhesive to re-attach to roof. It will look like new. $40 bucks and about
2 hours work and she looks like new.
1gasenvy1 is offline   Reply With Quote
Old 06-03-2009, 04:14 PM   #4
doug2060
doug2060 Normal reputation
A quick cheap way:
Take it outt and clean it off like Woodie said and use plain old elmers glue to paint the entire board (thin coat). Then pull the original cloth if possible tighly over it and let dry. I did this once. I know it sounds lame but it's a cheap and easy fix.
doug2060 is offline   Reply With Quote
Old 06-03-2009, 07:25 PM   #5
Johnny Mullet
Johnny Mullet's Avatar
Johnny Mullet Normal reputation
Send a message via MSN to Johnny Mullet
Go to Walmart or a fabric store and look for the "twist pins" They look like thumbtacks with pigtails. Screw them in with your desired pattern and colors and you now have a "quilted" headliner that stays off your head.
1997 Metro-----------1998 Metro
Johnny Mullet is offline   Reply With Quote
Old 06-03-2009, 10:01 PM   #6
Torqued
Thanks. Now that sounds quick, easy and cheap.
Old 06-04-2009, 08:23 AM   #7
1gasenvy1
I thought I was the cheap guy on this forum after all I have owned 6 Geos/Geo Metros/Chevy Metros...well, stick pins and re-gluing the fabric beat me. Keep em comming.
Bookmarks
Google
Web AF
