Re: Air Conditioning
Welcome aboard. Look at the A/C compressor clutch and see if it engages. The compressor is on the passenger side of the engine compartment. The clutch is on the inside of the pulley attached to the compressor. Look at it while someone turns on the A/C. It should suck in and start spinning. If it doesn't spin, it's a pretty good bet you have a leak in the system and you're low on refrigerant. The clutch won't engage if the refrigerant is low to prevent the compressor from destroying itself. You'll have to have it reserviced and have a dye put in the system to help find the leak. If it does spin, you may have a blockage somewhere in the system or a bad valve or again the refrigerant is low but, not enough to keep the clutch from engaging.
Check the A/C compressor clutch fuse in the IPM (fuse box) next to the battery if the clutch won't engage.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
