Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder/Terrano/QX4
Old 06-02-2009, 09:16 PM   #1
DOCTORBILL
Geo Metro Lover
DOCTORBILL's Avatar
DOCTORBILL Normal reputation
'95 Pathfinder Tachometer problems
I went to Spaulding Wrecking in Spokane today.
Asked the clerk about the Speedometer dash unit and he said Pathfinders always had a problem with the Tachometers.
He told me that the usual problem is normally in the Fusible Links on the Positive (+) battery post connector - bad connections.
So I looked at mine out in their parking lot.
I took the links out of the Battery side of the cable connector and re-inserted them.
The Tach then worked on the way home - EXCEPT - when I took the transmission out of overdrive (button out),
the Tach went crazy - needle flipped back and forth like crazy !
Then returned to working fine - with the overdrive button in.
I will scrape the contacts and coat them with Zinc Oxide Ointment.
That is an electronics repair trick I learned from my DAD who worked at an electronics plant
as the Head of R&D (Hallicrafter's Radio) in the 1950's and 60's.
I have no idea what is going on with the Overdrive selector button....
I suspect that the Tachometer itself is fine - just screwy connections somewhere in the
wiring - which must be very complicated.
I cannot find the Tach in the wiring diagrams in the Chilton Manual !
Has anyone had this problem with their Tachometer going bonzo ?
Was it fixable ?
DoctorBill
DOCTORBILL is offline   Reply With Quote
Bookmarks
Google
Web AF
