Re: 1991 Camry Heater-A/C fan inop
Sounds like the blower speed switch has gone bad. Sometimes as RIP mentioned you can remove and disassemble the switch to clean the contacts of built-up oxidation. Use a fine grit sandpaper (800-1000), then blow away any residue, apply a light coat of bulb grease, reassemble, and reinstall. If it still doesn't work, then the switch resistors could be bad (they typically run hot). Goood luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
