'92 4Runner with Speedo problem
Google
Web AF
sunniebch
05-27-2009, 10:05 AM
I have a speedometer problem; however, the symptoms are different. My speedometer ticks and only registers that I'm going 35 mph when I'm doing about 55 mph... any ideas?
thank you
fourwd1
05-28-2009, 10:20 AM
thank you
What year? engine? transmission? 2WD or 4WD?
sunniebch
05-30-2009, 07:37 AM
that would help!
1992
4wd
automatic
3.0
jdmccright
06-02-2009, 11:36 AM
First off and most importantly, welcome to AF! I've moved your post to its own thread so that it isn't lost in another thread with a different issue. Please also remember to refrain from reviving old posts unless there was no solution posted and you happen to have it. Thank you!
fourwd1
06-02-2009, 11:56 AM
Well that was helpful ................. NOT !
In 92 Toyota started going to electronic speedos, so you could have that or the normal cable driven one. You could have a problem with the cable (if you have one) or the gauge in the cluster. The cable is a fairly common cause due to lack of lubrication. Otherwise it's in the gauge in the cluster, which usually means replacement. It's rarely the sending unit. First thing would be to get underneath and see if it's cable or not. It comes out of the t-case, pass side.
Google
Web AF
