Re: 99 T&C Front Bearing?
Does it make a difference if using brakes or not? Maybe, I cannot get it to make the noise but I think it might of made a little difference in the pitch of the noise.
Does it make any noise if backing up and turning sharpley left or right? Cannot get the noise when I just tried this, I have not noticed this befire either.
Amother thing to try is find a lightly traveled road and drive about 45 MPH and swevre right to left and left to right to see if there is any difference in noise at either direction of swerving. Did not hear any noise when I did this.
Are you sure it is the hub you replaced that is making the noise? Pretty sure it is the same one but I never have enough time to be positive. Also cannot get the noise to occur on command.
I have only heard the noise while making right turns never heard it going left. Also it does not happen all the time which just makes it frustrating to determine the cause. Can a hub/bearing make noise when it is not under load ie right turn causes the right bearing to squeal?
