2000 Taurus drivers window goes down but not up
Ok, I searched the forum and couldn't find a similar problem. I have a 2000 Taurus. The drivers window switch will work down, but not up. When pushing the switch up, I hear the relays clicking. I removed the window motor from the door and bench tested it. Motor turns in both directions when given direct power from a spare 12V battery. I plugged the window motor back into the door connector (motor hanging free) and tried the switch again. Down and express down and the motor turns. Press window switch up and motor doesn't turn, just clicking relay. I even went ahead and replaced the relay. No change, same results. Any suggestions?
