Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee/Grand Cherokee SRT8
Old 05-30-2009, 05:34 PM   #1
LELeach
LELeach Normal reputation
Thumbs down Laredo Transmission Woes
94 JGC Laredo 4.0, 4X4 automatic, 201,000 miles, 90,000miles on factory reman transmission which has been flawless. After sitting unused for three weeks the transmission was slow to engage (start moving) when shifted into reverse. The transmission starts in high gear and remains in high gear. The OD light will not show when the OD switch is pressed. If the selector is placed in 1 the transmission will be in 2nd gear and will shift to 3rd when the lever is manually moved to Drive. OD will not function. The transmission fuse in the dashboard panel is ok and the 15amp transmission controller fuse in the engine compartment is ok. Techs in two different transmission shops get no communication from the transmission using their analyzer plugged into the transmission port accessed from the interior transmission tunnel. The fluid is at the proper level and is red with no smells and no discoloration. The on-board fault code shows the normal 55 with not fault codes. Any suggestions will be sincerely appreciated.
LELeach is offline   Reply With Quote
Old 06-09-2009, 01:00 PM   #2
fredjacksonsan
Sir...I AM a professional
fredjacksonsan's Avatar
fredjacksonsan Normal reputation
Send a message via AIM to fredjacksonsan
Re: Laredo Transmission Woes
How is the fluid level in the trans? These are sensitive to low levels of trans fluid.
AF's RULES can be found HERE -- Please read them.
fredjacksonsan is offline   Reply With Quote
Old 06-21-2009, 11:00 PM   #3
nova73noir
nova73noir's Avatar
nova73noir Normal reputation
after this 3 weeks ,your batterie was discharged???
98 grand cherokee 4.0
73 nova 350 powerglide
90 z-24 3.1
95 mustang 3.8
nova73noir is offline   Reply With Quote
Bookmarks
Google
Web AF
