power window scraping noise
Google
Web AF
drchemistry
05-30-2009, 05:26 PM
The drivers side power window on my 2001 Suburban (1500, 2wd) started making a scraping sound when moving both up and down. I removed the regulator and everything looked OK. Then I hooked the regulator back up to power with it out so I could watch it move up and down. I can't see anything wrong with it, but it still makes the nasty sound with it out operating on the ground (wo the glass). I greased it up thoroughly and it still makes the noise! The sounds seems mostly to come from the top right pulley, but no amount of lube has any effect. Any suggestions? Is this a common problem? :confused:
j cAT
05-30-2009, 09:21 PM
these plastic pulleys are pivoting on a rivet..oil 20wt with grafite mixed in an oil can usually stops most problems like this..
as you most likely know the cables and motors of these designed to fail window regulators are of the lowest quality...
drchemistry
06-07-2009, 10:06 PM
A couple of days after lubing it the regulator failed and would not roll the window up. I replaced it myself with a new one costing $213 at the dealer. If GM can't sell cars, at least they stay open selling parts.
j cAT
06-08-2009, 12:20 PM
in the future get your regulators at 1A auto in massachusetts...
free shipping....you can get 2 regulators and take your freind out to dinner with what you paid.....
I bought 1 from the dealer at 178.00.....then I found 1a auto...the quality of the regulator I got from 1a had heavier wires and the unit was well greased with white lithium..
other vehicles like 2003 2500 silverado I got 2 regulators for 130.oo total delivered,,,in 2 days...with a lifetime warrantee...with GM parts no warrantee...
drchemistry
06-16-2009, 10:16 PM
Thanks for the tip!
Google
Web AF
