96 Windstar 2 Month Wheel Bearing??tebo77 05-29-2009, 05:09 PM I got wheel bearings 2 months ago with hub, today I felt some play so I checked and sure enough, right hub is burning hot. I did the entire front end within the past 6 months...strut assembly including mount, axles, ball joints, tierods, strut rod bushings (and the welding of bushing sleeves), stab links, to try and avoid one part wearing/pressuring another. Also got new tires and an alignment when they were all done. Is there a certain brand bearing that is better quality? What would make a bearing go this quick? :confused: I've had Fords for several years and I know they can be front end eaters, but never had something wear this fast. Thanks for any help! Lbert 07-08-2009, 06:10 PM Did you every found out what the problem was? Assuming the wheel hub and knuckle are in good order, I wonder if the wheel bearing was not installed or pressed correctly. I am in the process of doing the same job. I have the same year model as yours, 1996. I got the same manufacturer of the original front wheel bearing, Timken. In addition, I am also getting a new wheel hub because the hub was trashed due to the worn bearing was not replaced sooner. I will be doing the passenger side first and the other side later. tebo77 07-08-2009, 09:26 PM I never found out, but I would guess it was pressed wrong, since this does not appear to be a common problem. I have been told one good pothole could damage a bearing, so who knows though. wiswind 07-08-2009, 09:33 PM My '96 has 213K miles on it. At about 183K miles the factory original wheel bearing on the passenger side was replaced. The driver side wheel bearing is still the original. When I saw the title....the first thing I thought of was to replace the hub & bearing....which gives you new bearing race along with the bearing......so you don't have a worn race to damage the new bearing. Otherwise Maybe you got a dud?..... Maybe something went wrong in the installation process? (although I don't know what would) I had mine done for me.....and I don't know if they replaced the hub or not. Lbert 07-09-2009, 07:43 PM A new Timken wheel bearing cost $30.00, new Ford hub $86.00, installation of the wheel bearing to the knuckle and wheel hub by a machine shop $30.00, and $10.00 to resurface the rotor. I also decided to replace the cv half shaft since the van is over 138k miles and I am already in the area. New cv half shaft $86 from Autozone- China made, and $9.00 for the new seal. I am having to re-surface the rotor due to some damage to the rotor's surface as a result of the bad bearing. tebo77 07-10-2009, 07:38 AM Could have been a dud. The snap ring was on so it had to be pressed all the way. I thought maybe the spindle was out of round but so far, so good with this one! Automotive Network, Inc., Copyright ©2012
