Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 05-29-2009, 04:21 PM   #1
burny36
burny36 Normal reputation
95 buick regal grand sport starting problems
my 95 buick regal grand sport starts fine when it is cold and will drive as long as you want. but once you park it for 15 min after it is hot it will not start. the engine will have to cool down before it can be started again.
the spark plugs have been replaced the fuel filter has been replaced and the fuel injectors have been cleaned.
what is wrong?
burny36 is offline   Reply With Quote
Old 05-29-2009, 10:32 PM   #2
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: 95 buick regal grand sport starting problems
Which engine, 3.1 or 3.8?
“Ye shall know the truth and the truth shall set you free."
HotZ28 is offline   Reply With Quote
Old 05-30-2009, 01:16 AM   #3
Ruley73
Ruley73's Avatar
Ruley73 Normal reputation
Gran Sport Regals only came with the 3800.
I'm thinking that the crankshaft position sensor is starting to fail. The sensor is unable to get a reference signal when you turn it over and ignition spark cannot be produced as a result.
Next time it won't start, have an assistant turn the car over while you pour water down the side of the engine near the crankshaft pulley. It should start within a few seconds when you do this.
My ride: blackberry 2000 Saturn SC2, 5-speed, lowered, bolt-ons
Wife's ride: white 2007 Chevy Equinox LT FWD...stock for now
Ruley73 is offline   Reply With Quote
Old 06-01-2009, 03:12 PM   #4
burny36
i drove the car today and it would not accelerate pas 50 miles per hour. when the gas peddle is floored the engine does not accelerate and seems to struggle to keep going. ive been reading on the forums and i am wondering if it could be the fuel pump resistor the or the pump itself. how would i be able to find out which it is.
Old 06-02-2009, 11:57 PM   #5
Ruley73
Ruley73's Avatar
My guess is that the plug wires are bad or the fuel pump is weak. One of the ignition coils could be bad too. I would also check the ground cable going to the engine. I'm not sure what fuel pump resistor you are referring to. If you mean the fuel pressure regulator, that typically causes hard cold starts and an occasional misfire at cruising speeds, but I don't believe that is your problem.
Old 06-03-2009, 09:31 PM   #6
burny36
today the car started great when it was cold. i pushed in the valve where you put a fuel pressure gauge and it squirted fuel at me. i drove it around and got it up to operating temperature. i parked it and shut the car off. waited about 5 min and the car would not start. i pulled a plug and it sparked, i pushed in the valve and fuel came out. i took a hose and sprayed down the cps and nothing changed it still wouldn't start or even sputter.
i noticed that the abs light is on and the security light is on. they are not blinking just on.
what do i do now?
Old 06-03-2009, 11:59 PM   #7
Ruley73
Ruley73's Avatar
what do i do now?
Does the ABS & security lights stay on after the engine is running? Also, when the engine won't start does it still turn over ok? Alternator may be going out if the starter doesn't turn over that well. Don't just assume it's fine because the battery light doesn't come on while the engine is running. They often times don't illuminate until alternator isn't charging AND the battery is almost dead.
Old 06-04-2009, 12:35 AM   #8
burny36
the lights stay on after the engine is running and the engine turns over like normal.
Old 06-05-2009, 05:44 AM   #9
Ruley73
Ruley73's Avatar
It could be a bad ignition switch or key. I know yours has the black resistor in the key. I used to have this exact same car.
I would also check the MAF sensor, and clean it with some brake cleaner if necessary. Don't use carb or throttlebody cleaner because those leave a small lubricating residue intended for lubing the throttleplate.
Old 06-05-2009, 02:38 PM   #10
bs009
bs009 Normal reputation
almost sounds like a coolant issue.
bs009 is offline   Reply With Quote
Old 06-07-2009, 06:59 PM   #11
burny36
what could the coolant be doing to make this happen?
Old 06-08-2009, 11:36 AM   #12
Ruley73
Ruley73's Avatar
That's what I was wondering too!? Maybe a headgasket - what does your exhaust look like?
That would be a first for me - seeing a 3800 with a bad head gasket.
Old 06-08-2009, 03:55 PM   #13
bs009
this just reminded me of how when my brother's car was running hot, the car wouldn't accelerate and would seem like it was missing, and when he tried to start it all it would do is crank. later he fixed some coolant issue and it was fine. However, that was with a different engine....
try checking the fuel pressure with a pressure gauge when your car doesn't start; your fuel pump could be on its way out. As Ruley stated, you should also check the engine grounds. if you have a bad ground then that could cause your injectors to not pulse.
I doubt that the problem is with your key. Usually when there's an issue with the resistor, it causes your car to not start. I don't think it affects the car when it's already on.
are you getting a SES light? Does it even turn on when you put the car in run before you start it? how many miles does your car have?
Old 06-08-2009, 06:03 PM   #14
burny36
the exhaust has a hint of white but nothing outrageous.
Old 06-08-2009, 06:06 PM   #15
burny36
no ses light, I'm working on getting a fuel pressure gauge, it has around 130,000 miles.
Bookmarks
Google
Web AF
