Originally Posted by amphere
I have a 2005 Pathfinder. The AC will only come on when the fan speed is on 1, if you turn the fan higher the AC light goes off but if you turn it back to 1 it comes back on. Sometimes it will work on all 4 fan speeds but usually not. I have been told it may be the blower motor resister. Can anyone tell me where the resister is located and how to test it? Thanks.
the resistors are a block usually mounted in the fan assy t
here are a number of terminals you should get ba resistance reading with an ohm meter resistance should increase as you change from 1 terminal to another
resistors are in series with each other
