I have a 99 tahoe with 175000 mi and had a few general questions regarding power. I've noticed over the years a definite drop off in power especially climbing hills. Getting up to highway speeds and so on... I changed the plugs, wires last year. I know the truck is old and don't expect miracles but an improvement would be nice. I mean it still runs and shifts well don't get me wrong. Anything obvious I should be replacing after owning the truck for 100 000 mi. I've done next to nothing in 5 years. Intake, plugs, wires and that's about it. Thanks for your help.
Have the 02 sensors ever been replaced? 100,000 miles is the recommended replacement for them. The CATS also do not last forever and might be starting to plug up.
Fuel Pressure should be checked as well. Last fuel filter replacement? A weak pump can cause loss of power under a load.
Might want to have the compression tested. A leak down test can also pinpoint mechanical issues.
is there any way of telling if a cat is fouled up or bad? Can these be cleaned in any way? so replacing the o2 sensors should already have been done, so i'll go ahead and replace these and look for any improvements. Also how would you clean a mass air flow sensor, soap and water? thank you
"throttle body needs cleaning with throttle body cleaner and a tooth brush to gently remove deposits....the IAC must not be forcefully cleaned just gently brush off the deposits with the cleaner aiding this.since the air ducting must be removed clean the MAF sensor wires...use CRC MAF cleaner,,,just spray cleaner on the small sensor wires do not touch wires....let dry then reinstall."
Reason: Typo
The only way to test the cats for restriction is to do an exhaust back pressure test.
Most likely cause for your concern is plugged fuel injectors...now before you jump in and clean them or before you listen to some self perclaimed "expert" about injecor cleaning, do some research..I have posted extensively about the injector set up on these engines and what needs to be done.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
