Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 05-27-2009, 09:18 PM   #1
kshook.2
kshook.2's Avatar
kshook.2 Normal reputation
1995 caprice power steering gear box
how hard would it be to replace all internal seals of the power steering gear box i would like to rebuild it how hard is it and what all is involved thanks
kshook.2 is offline   Reply With Quote
Old 05-28-2009, 08:29 PM   #2
j cAT
j cAT Normal reputation
Re: 1995 caprice power steering gear box
why ? if you have a small leak replace all the fluid and add a p/s seal conditioner....give it a couple of weeks ....
replace the fluid every 5 years...
j cAT is offline   Reply With Quote
Old 05-28-2009, 08:37 PM   #3
kshook.2
kshook.2's Avatar
i have and it still leaks so now i whant to rebuild it thanks
Old 05-28-2009, 08:41 PM   #4
j cAT
what fluid did you use...what sealer product and how much..
are you sure its not the p/s line that goes accross the nose...below radiator..
Old 05-28-2009, 08:50 PM   #5
kshook.2
kshook.2's Avatar
i used prestone seal conditioner stop leak i used a hole bottle one quart no it is leaking from gear box lower control arm their are no lines leaking thanks
Old 05-28-2009, 09:00 PM   #6
j cAT
you have to replace the fluid ,,,,then do the sealer ...usually a few ounces over 2 weeks and it will stop....replace the fluid the seals will soften slowly....my vehicle had some leaks 2 years ago and its still fine ...also my 2000 sil had some leakage did both both still good..
used this product on other vehicles...never fail to stop the leak...
one time the output seal blew on a vehicle that was damaged by an accident that seal was a messey job..if that is leaking I would have a shop do it..
when I say blew I mean oil just drained out puddles...the seal on removal was cracked..
Old 05-28-2009, 09:07 PM   #7
kshook.2
kshook.2's Avatar
if i let it sit for two days their is a puddle i have draind all fluid and then used just the prestone it slowed but didint stop thanks
Old 05-29-2009, 11:32 AM   #8
j cAT
it must be the output seal...does it leak at the pitman arm steering box output shaft??? if so this seal should be replaced...
after removal of the pitman arm and the C clips that lock in this seal ...start the engine and turn the steering wheel hard left/right the high pressure will blow out the old seal....then re-install new...
if the vehicle was with damage to the front wheels ,,,this seal will crack...hitting curbs other vehicles etc....
Old 05-29-2009, 10:49 PM   #9
kshook.2
kshook.2's Avatar
yea it is leaking from their the front end was damaged a little bit i replaced every thing but the gear box
Old 05-29-2009, 11:38 PM   #10
toddman67
toddman67 Normal reputation
If the front end got wacked hard enough to cause a PS gear box to leak perhaps you should consider replacing the whole unit.
$160 at advance auto. Probably cheaper at a salvage yard.
Seals cant stop a leak if the housing is cracked.
toddman67 is offline   Reply With Quote
Old 05-29-2009, 11:43 PM   #11
kshook.2
kshook.2's Avatar
ill will try to put a new on if i cant find it at the self pull yard thanks
Old 05-30-2009, 10:15 AM   #12
j cAT
replacing the rubber seal is what is most likely the problem...as I stated before a good whack will cause the SEAL TO CRACK...not the housing being cracked...
Bookmarks
Google
Web AF
