Thanks for the reply.
I have just one keyfob but I am currently looking on eBay for another. As for your suggestion to re-program the current one, I will follow it with the hope that it will fix the problem.
I do not know what RCDLR module stands for, but I assume it is the receiver module. I thought it might be the culprit because
I found a post in the Regal forum at AF with a link to
http://www.w-body.com/service/keyless-entry.html
which says that the receiver module might be the cause of irregularities in the keyless functions. So I thought I would try to take a look at it... Maybe there are some connections needing resoldering... although if the module is under the dash, it is hard to imagine what would cause their corrosion or something like that....
Originally Posted by BNaylor
I'll double check the service manual but it should be located in the dash about the center area. It doesn't sound like the RCDLR module since the other functions on the keyfob work. Have you tried another keyfob or reprogramming the current one used?
