Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Explorer/Explorer Sport Trac
Old 05-25-2009, 09:28 PM   #1
mansopoor
mansopoor Normal reputation
wont stay running in "D" or "R"
let me start by telling you this is for my brother's truck. its a 92 explorer with a 4.0L. from what i understand he put some antifreeze in it and that is when the trouble started. in "P" amd "N" he can start it and rev up the engine, but when he puts it in "D" or "R" it stalls out. he says its like it not getting fuel, but i told him "if it wasnt getting fuel it would stall out in "P" and "N" and NOT rev up" can someone please help me with this one. thanks.
mansopoor is offline   Reply With Quote
Old 05-25-2009, 10:03 PM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Re: wont stay running in "D" or "R"
Sounds like maybe he has a significant vacuum leak that causes the engine to stall as soon as he puts a load on it. Did he maybe knock off the intake air hose or disconnect the MAF sensor plug?
-Rod
shorod is offline   Reply With Quote
Old 05-26-2009, 07:45 PM   #3
mansopoor
ok i got some new info on the truck. when in "P" or "N" idles ok but when he steps on the gas it hesitates for a second and the revs up. now when it in "D" or "R" i think it idles ok but then he steps on the gas it sputters and dies, but if he feathers the gas then he can get it to move
Old 05-26-2009, 10:56 PM   #4
shorod
Taurus Guy
shorod's Avatar
I still think he needs to check for vacuum leaks and a misfire/plugs/wires.
-Rod
Old 05-28-2009, 02:57 AM   #5
XLT03
XLT03 Normal reputation
I had 92 also with similar problem. Check for vacuum leak on left side of intake. There is a vacuum port with four ports for vacuum modulator, power brake booster etc. If any of those ports are left uncover it'll exhibit symptoms you described. I believe one port is not used and need to have port capped. Very easy for hoses to come off if vacuum modulator had a leak now or previously and ATF got sucked up into this port and the rubber hoses got oily and swelled slightly.
XLT03 is offline   Reply With Quote
Bookmarks
Google
Web AF
