Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 05-25-2009, 08:52 PM   #1
302Z28
302Z28 Normal reputation
'97 cav 2.2 stalling
My '97 cav has started stalling, usually under very light throttle. When idiling, (in gear, foot on brake), turning the steering wheel to either side will stall the motor. I've removed, cleaned and adjusted the Idle Air Solenoid and bore that it seats in, but nothing. What is supposed to maintain the idle speed?
Also noticed that disconnecting the battery for 30 minutes seems to help the performance for a short time.
Could anyone offer any advice?
Thanks,
302Z28 is offline   Reply With Quote
Old 05-26-2009, 06:39 PM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: '97 cav 2.2 stalling
The IAC is all that is used to hold a steady idle speed. I believe there is also a power steering pressure switch that makes the PCM increase the idle when the pressure increases in the line, which counters the extra load of the P/S pump. Not every vehicle has one, but most do, I'm not 100% sure if the Cavaliers have one or not. Check to see if it loses spark or fuel when it dies.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is offline   Reply With Quote
Bookmarks
Google
Web AF
