Got any trim pics?
Scourge
10-23-2001, 09:18 PM
I am wanting to put on 31 10.5 15 Pirelli Scorpion A/ts on my 2000 4x4 XE 3-pack. I would like to keep the front mud flaps on. How much trimming is involved so there is no rubbing. Does anyone have pics of the trim work.
Scourge
10-24-2001, 05:57 PM
22 views and no takers?
ScottG
10-24-2001, 06:20 PM
When I saw the subject heading I thought you were looking for porn:D
Seriously, I remember seeing some pictures of the trimming on the Unofficial Board over a year ago. If anyone still has them, it would probably be Brent (OffroadX).
Scourge
10-24-2001, 06:59 PM
Oh, I guess my mind is stuck in porn mode :frog:
Brent do you still have those trim pics?
Schludwiller
10-24-2001, 08:33 PM
Well I was going to reply that you won't be able to keep your mud flaps, but then someone somewhere bent them back enough to keep 'em, so I can't say definitvely.
Personally I find the mudflaps to be a liability when offroading. I'll probably implement a soft-rubber solution someday.
The new Nissan trim allow for larger tires and flaps, but I don't own a 2002, just know they're designed to allow the 17" wheel and tire (which is the biggest Nissan is running now).
So get the 31's. Just don't be too dissapointed if you have to cut off your mudflaps.
rrdstarr
10-24-2001, 08:43 PM
EOE sliderz make great mud flaps! I notice a lot less debris slung onto the truck vs. everyone else this weekend! I still retain my rear mudflaps just becuse i don't like throwing rocks at other people! I run 31" TSL's and had to trim about an inch on the front and rear from the front wheel well.
But here is a link from our PNWX site on what to trim:
http://home.earthlink.net/~ddmoore/fsrbiker.html
OffroadX
10-25-2001, 10:25 AM
Nope, I don't have pics of the trimming per se. Other than the ones just posted, I know Ian has a better picture of the initial trimming he did. However, this pic of the '02 flare/flap setup pretty much shows the same trimming you would have to do yourself (same overall flare on the '02s, they just modified the bottom edge)
http://home.us.net/~stimpy/xterra/2002/02frontflap.jpg
Brent
rrdstarr
10-25-2001, 01:54 PM
I wonder if the '02 flaps will fit on the older model truck? Looks pretty similar? You'd just have to drill a new hole for that one that is up and inboard.
OffroadX
10-25-2001, 03:04 PM
Yes, as far as I could tell, they will. The general dimensions of the flare have not changed.
Brent
Scourge
10-25-2001, 08:42 PM
thanks to all. Great help!
Schludwiller
10-25-2001, 11:03 PM
Probably, but you will still break it off after decending over the first rock you climb over. The EOE's do a good job as it is.
lemsip
10-30-2001, 08:10 PM
If Ian doesn't mind me linking to his picture....
http://www.xterrain.com/images/fendertrim.jpg
Philosopher
10-31-2001, 01:13 PM
Jesus Christ, if only the rest of us could have gotten away with trimming that little bit ...
Schludwiller
10-31-2001, 01:26 PM
Those are 31" AT's. That pic was before he got the lift and went to 32" MT's.
Philosopher
10-31-2001, 03:27 PM
I know.
Goliath the X
10-31-2001, 09:16 PM
Here is what I trimmed for 31"
rrdstarr
10-31-2001, 10:27 PM
Goliath, I have made the exact same cuts with a little $3.00 coping saw.
