Re: 93 cav 2.2 emissions control??
I'd check the compression across all the cylinders, could be a blown head gasket dripping water into the cylinders. Burning very dirty coolant is a bit greyish (but mostly white, as coolant smoke generally is), and very dirty coolant could have destroyed the head gasket. That's where I would start. Also check for a leaking fuel pressure regulator. Pull the vacuum hose off of it, it should be dry inside. If it is wet, it's leaking fuel into the engine and running rich, which would make black smoke.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
