93 Altima wont startjohnnybhai 05-24-2009, 06:57 PM The battery is fine/new. I checked the voltage on the device that had a coil inside it - in front of the engine, to the left of it as I am facing the front of the car (starter? alternator?) and that was 12V as well. So I think the connections are fine. Does that mean the starter is broken? What do I need to check next? I also opened up the ignition switch area of the car, near the steering wheel well - but I am not sure what to check in there to see if the ignition switch is broken. Is there any way I can get a diagram of the wires in that area, to see what should go where - to determine if anything's loose. Thanks a lot for all your assistance. johnnybhai 05-29-2009, 07:09 PM bump x1gary 06-27-2009, 11:56 PM Do you hear a click when you try and start the car? It may be the starter... try and tap it with a hammer while someone is starting the car. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
