Re: 97 accord overheating
Some A/C systems will make noises as the pressures on the high and low side equalize after shut off...but you could be hearing vapor hammer in the engine coolant passages too if it's running hot or has a large volume of air in it...running with A/C on is gonna make the cooling system retain more heat, so it's possible. Makes sure both fans are running while the A/C is on, if the secondary is not working, it'll really heat up the rad with A/C operation...
It's pretty common for Accords to split a seam or tank on top of the radiator...particularly if they've had any front end body damage or offroad underside jang...the subframe crossmember below the radiator deforms pretty easily, and puts the radiator mounts in a bind, eventually breaking the radiator from stress...pay attention when you loosen the radiator mounts to see if springs or spreads out slightly...make sure you make allowances when reinstalling or it'll wreck the new one pretty quickly too.
I had a kind of similar problem with the wife's Accord, long story but it split the upper tank, was losing about the same amount you describe, but then began to really overheat bad at some point...I hadn't seen a car that would overheat so explosively from a minor coolant/pressure loss before, so I almost had myself convinced it was a bad head gasket...like you, I'd also changed the T-stat early on, so I knew that wasn't the problem.
But after a radiator replacement, all is well again...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
