Re: noise in driver's side front
Two possibilities that I can think of, the first is worn/separated lower control arm bushings, the other is the strut mounts. To check, have a friend bounce the car on the ground and see if you can feel movement in any of the suspension components. Do it 3 ways. Pushing down on the bumper/rad support, pushing down on the LF fender, and rocking the car back and forth by pushing near the "B" pillar. Either of these being bad could cause all the noises you are hearing. I've never heard CV joints make noise except for a rapid popping on sharp turns.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
