Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 05-23-2009, 08:07 PM   #1
smileyjr
smileyjr Normal reputation
disributor installation
i changed the ditributor from my old engine to the one i just bought , i turn the crank and line the mark with the line on the block itself because neither engine has the little timing mark indicator , also i set the rotor button pointing the the #1 plug wire on the distributor cailooked in the engine to see if i could see the top of the piston (i did) so did i do this procedure right because the engine wont start also do this engine suppose to have a timing mark indicator
smileyjr is offline   Reply With Quote
Old 05-23-2009, 09:16 PM   #2
toddman67
toddman67 Normal reputation
Re: disributor installation
You may very well have the distributor off by 180 deg. Put the piston back up to top dead center and pull the dist. Put it back in pointing to #6.
toddman67 is offline   Reply With Quote
Old 05-23-2009, 10:01 PM   #3
smileyjr
#6 cylinder or plug wire at the distributor
Old 05-23-2009, 10:32 PM   #4
toddman67
When you installed the distributor it is possible that you were on the exhaust stroke for #1. To check for certain you need to pull the valve cover of and bar the engine over. Watch for the intake valve to open, keep barring the engine over until the valve closes and the piston comes up to TDC. Now you can install the distributor pointing to the #1 on the cap.
If the rotor was pointing to#6 At TDC you were 180 deg. off
Old 05-27-2009, 11:16 AM   #5
herkyhawki
herkyhawki Normal reputation
What is the engine??? 6 cyl or 8 cyl.?
Follow the procedure #2 in this document and it will work the first time. http://www.justanswer.com/uploads/Bl...eplacement.pdf
This is written for 5.7L 8 cyl. If you havwe the 4.3 L 6cyl, then the dist will point to the #6 insteasd of #8. This 6 and 8 does not refer to cylinder number, but the total number of cylinders in the engine. Both the 6 cyl and 8 cyl distributor use the same casting so the 6 and 8 are both cast in.
herkyhawki is offline   Reply With Quote
Bookmarks
Google
Web AF
