i have all the bolts for the transfer case off the drive lines and any bolt or electrical off but the transfer case will not separate all the way from the transmission. Does any one know why. It has about 6-9 mm of separation from prying and tapping but will not go further please help!!!!
According to Alldata You should have removed four bolts and two nuts. You may have forgotten one. Also, double check that you have all wiring and linkage disconnected and check for vent hoses at the top that may be preventing you from sliding it off.
99 Rodeo LS V-6, 4wd, 31x10.5x15 not lifted, Aisin manual hubs.
