Re: 1999 Durango front Hub spindle nut
It is a 32mm,you can use an 1 1/4" socket too.I have use an 1 1/4 socket and fits just fine.Tapping the spindle with a mallet will not work,tapping on it carefully with a hammer works better.Sometimes the wheelbearing will not come out easy.Chrysler screwed this up in 2004 in the fullsize trucks,the tolerances between the spindle and the wheelbearing are set way too tight.
