how much is to much?
all power
05-23-2009, 01:00 PM
i my other thread i asked can i get 300hp out of my motor and everybody said yes but the ? i forgot to ask is how much will it run me????? this is what i was told so tell me what you think and if you can give me a ballpark guess?????? 1.0PCM/HEADERS/NEW PIPES/ C.A.I/3.4 PULLEYT.B SPACER/FLOWMASTERS 40SEIRES/
jakegday
05-23-2009, 03:26 PM
where do you plan on getting the "1.0 pcm" from??
GTP Dad
05-23-2009, 04:13 PM
You should be able to do everything for around $1500 if you do the work yourself. If you have it done by someone add about $1000 for labor.
all power
05-23-2009, 05:18 PM
zz per/3800 per is there a diff?
richtazz
05-24-2009, 10:13 PM
The exhaust mods are the biggest part of the expense, but GTP Dad is right there with his estimate. Also, if you're going hi-flow cat, a post-cat o2 simulator might be a good bet also.
tblake
05-25-2009, 10:38 AM
I agree Rich, but look into others besides the one from ZZP, mine went bad after a a few months of service. I just plugged my O2 back in so I only get the P0420 code once ever few days instead of the P0138 constantly.
I have a powertuner on the way so I can just delete the P0420 out of the PCM.
If your going to buy a PCM, look into getting the P0420 code removed. It might be a bit more expensive, but it will save you money and headaches in the future. :banghead:
BTW, I have heard of quality issues with ZZP PCM's lately.
jakegday
05-25-2009, 02:06 PM
as far as PCMs go, no. none at all. since i bought my grand prix ive been surfing the grand prix forum sites and have read nothing but negative stuff about ZZP/3800performacne PCMs. i plan on getting one from overkill motorsports. ive also read great stuff about www.intense-racing.com PCMs
GTP Dad
05-25-2009, 04:53 PM
Personally I would go with a DHP tuned PCM. I have seen a number of engines that were damaged running the Intense PCM's.
tblake
05-25-2009, 07:12 PM
Damaged Engines from an intense PCM? Thats no good!
