Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 05-22-2009, 11:14 PM   #1
Ej091
Ej091 Normal reputation
99 z24- nightmare stereo installation
I wouldnt pay $50 to install a stereo so i figured i could install a vr3 head unit myself and when i had it all wired up I turned the car on and heard a shocking noise. Now my dome lights, door locks, power mirror, keyless entry, and radio are out. The package for the stereo says if installed improperly it could seriously damage my vehicles electrical system. Is it just a fuse or am i screwed? Btw, im new here
Ej091 is offline   Reply With Quote
Old 05-23-2009, 03:55 AM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: 99 z24- nightmare stereo installation
Welcome to AF!
Two things that could very easily cause this. First, is that you joined the wires incorrectly and had a short to ground as a result. Read this. Second is that you joined the incorrect wires. You need a vehicle wiring diagram and a stereo wiring diagram. Join the appropriate wires, from what I have seen, colors rarely match up from the vehicle to the stereo. Take your time, do one wire at a time, and double check the whole thing when you're done. After you get the adapter wired up correctly (I'm hoping you bought the adapter and didn't cut up the vehicle wiring), check all the fuses. It's possible you damaged the stereo depending on what wire went where, but the car is most likely fine. Hopefully the only damage you did was to the fuses.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is online now   Reply With Quote
Bookmarks
Google
Web AF
