00' GP car charger doesn't work!!Firstymer 05-22-2009, 05:42 PM I recently purchased a GPS and as I tried to charge it in my 00' GP 3.1L v6 IT DOESN'T WORK...I recently there were several lose or cut wires behind the console please help me fix this minor electrical problem... oldblu65 06-01-2009, 02:35 AM If you have any mechanical or electrical experience , you can reattach the wires ( if you're sure where they go ). If you don't have the experience or confidence to do the job yourself , you should take it to a SAE certified mechanic for the repairs . Good luck ! Just my :2cents: ! richtazz 06-01-2009, 09:04 AM The problem with finding cut wires is figuring out why they were cut. If there is a dead short somewhere, reattaching the wires is just going to blow fuses. If some hamfisted idiot trying to install an aftermarket stereo just starting hacking, reattaching the wires may fix everything. Firstymer 06-01-2009, 11:13 AM The problem with finding cut wires is figuring out why they were cut. If there is a dead short somewhere, reattaching the wires is just going to blow fuses. If some hamfisted idiot trying to install an aftermarket stereo just starting hacking, reattaching the wires may fix everything. The stock stereo is working fine and everything light inside the dash work fine...I am unclear why the car charger is not working tblake 06-01-2009, 10:27 PM check the fuses. Sometimes smokers who run the indash cigarette lighter too long blow the fuse. Firstymer 06-02-2009, 12:41 AM I know the fuses box on the dash side of the dashboard. What is the number of the fuse so I can find it? tblake 06-02-2009, 08:16 PM I dont know. check the underside of the fuse box cover. Firstymer 06-02-2009, 08:34 PM THANKS for the help! Tomorrow I will definitely check it out. Automotive Network, Inc., Copyright ©2012
