Short block replacement..other parts to replace
Google
Web AF
laxman21
05-22-2009, 02:14 PM
Having a new long block put in my 99 blazer.
Shop is recommending these parts..additional $850
distributor cap, rotor, spark plugs, oil filter, serpentine belt, thermostat, water pump, oil pressure switch, temperature switch, timing cover, starter, motor mount, oil pickup tube
I think I need only:
motor mount, oil pickup tube and timing cover
Manual(chiltons) say timing cover need to be replaced if removing it as it may leak.
What do you guys think?
Rick Norwood
05-22-2009, 02:29 PM
I don't use short blocks, only long blocks. By the time they re-do the heads, you'll be at the same price. If they weren't planning to do the heads, that is just plain wrong.
Don't skimp, you want as many new parts as you can afford. You don't want to be trouble shooting a fresh motor because of old worn out parts. And if nothing else, A NEW OIL PUMP ALWAYS.
laxman21
05-22-2009, 04:03 PM
Long block....sorry
ATK engine
Google
Web AF
