Re: 2007 Chevy Suburban Dead!! Won't Crank
(1) Check the ignition switch/circuit. Put a 12 volt test light or voltmeter acoss ground and the small terminal on the starter, have helper keep turning the key to start, back to off, etc., numerous times. That wire from the ignition switch should light the test light or read 12 volts EACH time the key is turned to start position.
(2) if above does deliver voltage to the starter, consider that the starter may be bad, remove it and have it tested for free at store like AutoZone.
(3) If one does not deliver voltage, track down the reason. It could be a bad neutral safety switch, try jiggling the transmission lever and try starting in neutral as well as park.
I'm assuming that it's not the battery becaus eyou swapped it out. I'll assume that your battery cables are also clean and OK, you're only 2 years old.
